I reconnected my Generator from AC in 2 to AC in 1 so I could Limit the Generator current to 20 Amp max. (Generator has 5 kw or 22 Amps at 220 V).
Now the AC out 2 Output on which the air conditions are connected shuts off with Minimum load (aprox. 3 Amps). After waiting 2 minutes it reconnects and the same occurs. What could be the Problem? i did not change anything but exchanging the Generator/land Connection ?
