I have a hybrid system using ESS with a CCGX. After the update of the inverter, the CCGX started to show"ESS#1#2". What does this mean?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Here is a list of the ESS codes:
https://www.victronenergy.com/live/ccgx:start#features_for_ess
#1 SOC low
#2 BatteryLife is active.
@WKirby thank you for the list. According to it, #1 : SOC is low and #2 : BatteryLife is active. For my system i set a SOCmin = 85%. Now while SOC=96%, the CCGX shows #1 although the battery is not low. So..
What type and size of battery do you have?
What are your "DC-low" configurations on the "Inverter" tab in VE.Configure?
Also what are your dynamic cutoff Voltage settings in the ESS assistant?
1) What type and size of battery do you have? 4 Gel batteries /200Ah-12 V. We have 2 series and 2 parallels which give a capacity of 400 Ah
2) What are your "DC-low" configurations on the "Inverter" tab in VE.Configure?
3) Also what are your dynamic cutoff Voltage settings in the ESS assistant?
Hello. Sorry, I lost track of this.
Those settings all look good to me.
Another thing, when you said that you updated the inverter, you did a firmware update right? What version, and also did you update the Assistant? Right click to update and see Assistant ID, now it is 0171.
4 People are following this question.
