martincole avatar image
martincole asked
MultiPlus Compact repeatedly switching between shore power and battery
Hi
I have a multiplus compact 12volt / 1600s / 70 amp
The unit less than 7 months old since installed in new RV.
Everything has been fine then suddenly we notice that the unit is switching to inverter and back again to power, sometimes 5-6 times per min. The 2-3 times a min. It only stays on inverter for a few seconds then back to power.
Murray van Graan avatar image
Murray van Graan answered ·
Hi @MartinCole. That could be normal behaviour, but depends on how it’s set up. Do you have a Venus or Color Control connected to it? This will enable you to see why the unit is doing that. A big possibility is that the input voltage moves outside of the specified input voltage parameters, and then the multi would switch to inverter mode. If you don’t have a Venus or Color Control, use a multimeter to monitor the input voltage on the AC in terminals and see what happens.
martincole answered ·
Thanks. The guy next door just turned off his Air con to his RV and everything returned to normal. I suspect like you say fluctuating voltage going below the threshold.
