I just ran the calculator tool using two SPM215-24 modules connected in parallel and the controller was the MPPT 100/50. The configuration was Accepted. When I looked at the calculation tap in the work book I noticed in the module Info there was a RED set of numbers that read 35.84 A Impp output @25 degrees C. What does this mean?
Also on the FORMS tab where it states Max. current @MPP min. temp 39.8A and Max. current @ MPP max temp 28.9 A is this the current that I could expect the battery will receive under bulk conditions assuming the sun is directly over head.
I wish there was a good document that explained how to interpret the spread sheet output tabs.
Thanks
