john2019 avatar image
john2019 asked
Modbus Reading mutiplus
Hi, All
I use a MK3 cable to connect with mutiplus. I downloaded two softwares ModScan and Modbus poll and try to read 04 input register. I set slave unit ID is 246 (from CCGX) address is from 15 to 20 (not sure correct) length is 6... baud rate 9600 , word length 8 , no parity and close bit 1....... But can not get response from mutiplus. Any suggestion for software and settings to read infor from mutiplus or CCgx. Many thanks
Modbus TCP
Ole Saether avatar image
Ole Saether answered ·
As far as I know, the Multuplus does not support Modbus over the MK3 dongle. You need to connect the Multiplus to the CCGX with a VE.Bus cable and then you can access it over ModbusTCP via the CCGX. See the CCGX manual on how to connect them together:
https://www.victronenergy.com/live/ccgx:start
