I build a BMS for my LTO battery and do want to control the charger with a SSR relay. I do assume, that I need to connect the SSR relay the "oppposite" way, which means L1/L2 connectors reverse since the current will flow reverse as well (from MPPT to battery).
Any suggestions? - Thank you!
