On the 500amp/50mva shunt there is a temp sensor wire connected to the B1 (red) and B2 (black) position. My system has two battery packs. The second battery pack is not monitored by the BMV 712 guage as it is downstream of the shunt. If I remove the temp sensor wire and install two power leads, one to B1 and the second downstream battery pack to B2 will the BMV 712 include both battery packs in it's readings?
