I've got 2. 24v 200ah victron energy li smart batteries wired in parallel to the multiplus 24 3000 with a ve bus BMS
Do the internal temperature sensors in the smart batteries report to the BMS for low temperature and high temperature shut down? Or do I have to buy and install an external temperature sensor and hook it to something
I also have a victron energy 220 battery protect wired into my DC loads and connected to the BMS do I need to program low voltage cut out into the battery protect if so what is a safe voltage? Or should I leave it as it came from the factory and just let the BMS shut it off?
