Please excuse my grammar I have a head injury.
My caravan is factory fitted with a 80w mono solar panel and 150w PWM solar controller, I have replaced the solar controller with a new Victron smart 75/15 MPPT, I have set it all up and removed the pin, all works fine.
My caravan has a new 110amp 12volt Yuasa lead acid leisure battery, I now wish to add an addition 80w solar panel and connect up both the panels in series giving 160w. I intend to replace the original factory fitted 2.5mm wiring from the solar controller with 4 metres of 4.5mm to reduce voltage losses.
My question will the Victron smart controller now recognise the new solar 24v setup or do I have to alter something in the settings?
