danglin avatar image
danglin asked
BMV 700 series. Retention of settings with fuse replacement
I have the BMV712 and finally feel that I have the setup optimal but want to replace the 100 mA inline fuse with the 1 amp size to correct the voltage discrepancy I'm seeing vs voltages from two multimeters, including.a Fluke. Are the BMV settings maintained with loss of power from changeout of the fuse?
BMV Battery Monitor
You will lose the current SOC (you have to make a full charge) and maybe some of the history, but not your settings.
To be save you also can backup the settings with VictronConnect.
