We have two paralleled 24/3000/70/50's and a CCGX
All seems to be working ok.
I was having some issues with the multiplus disconnecting from the generator a 7.2 kva unit when the load was initially put on however I have connected a lamp and the frequency is now far more stable and seems to have sorted that.
However, I was looking at the settings I have used and while the grid (shore power) voltage is around 230 here, the multiplus output voltage is set to 230 and the generator is nearer 240v! Could this be the route of my problems (pretty intermittent) or would the multiplus just adapt to the changing voltage from the differing sources?
The changeover is done with a simple changeover switch.
