neville-pittman avatar image
neville-pittman asked
Controller draining battery
My boat is laid up for the winter and the solar panel removed. However the VictronConnect smart controller is still connected and my batteries are running down over a couple of weeks. Does the controller use much power when no panel connected? If so can I switch off the controller without having to disconnect the battery connections?
Battery Protect
yannick avatar image
yannick answered ·
Fastest method is to remove the fuse. Personally i would disconnect my batteries to be sure nothing is draining Them.
