... thoroughly reading documentation I have stumble over the fact that ESS Assistant has a rate limiter at 400W per second . This may explain why the negative feedback loop of the system is so slow.
Also, my perception is that LOM Type has something to do with that because is directly related with input impedance . Is that true?
Is it possible to have the rate limiter as a user configurable option in ESS assistant setup wizard?
@mvader (Victron Energy Staff)
Thanks you,
Mihai
