I am connecting the Multiplus to a Lynx distributor. The manual states that the recommended cable size is 2 x 50mm and the recommended fuse size is 400A. Oceanflex 50mm is rated at 345A so I am assuming that I would install two x 200A fuses in the distributor.
Is this correct?
