firmware 180633.VFF, apparently no VE.bus. Has only the remote control rj45 connector.
Which interface to usb can I use with the vconfigure software? Is it Mk2.2b or mk3?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Hi @rvpost
Are you sure it's just 6 digits?
if it's 18xxxxx (7 digits) then you can use an MK2 and VE.Config or Victron Connect.
(edited: I incorrectly wrote that MK3 was compatible.)
see also:
https://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf
Thanks,
Appears I missed a diget, it is actually 1806133.VFF.
That should mean it is MK3 compatible.
Hi @rvpost
My apologies, I gave an incorrect answer before... 18xx is older and needs MK2...
I'll change my first answer...
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
Updating VE.Bus firmware, using VEFlash (Depreciated)
9 People are following this question.
