On systems with more than one GX present using the the same Router to access the web link ( same web IP )
The VRM portal appears to be mixing the data from both GX's not separating these data streams correctly.
it appears to be not using the MAC data in each packet all of the time to sort the data stream but appears to assume that the IP address of source Data is all that is needed. ( blocks use of common routers between multiple systems. )
any one else had this issue? Are there any known work arounds?
