Hi there. I would like to replace the Gel house batteries in a boat to lithium. The boat has a 160a alternator for the house batteries and a 60a alternator for the 12v lead acid start battery, ideally I would like to leave it like this. The installation will have 2 x Pylon teech 12v lithium batteries. I would like to use an isolated Orion smart 12 30 DC to DC converter between the alternator and the pylontech battery's, however ont he Victron diagram it shows that a lead acid battey or similar be installed between the alternator and the orion. Is this necessary or can I just connect the alternator to the Lithium battery ( the Plyon tech batteries have a built in BMS which will communicate with the cerbo GX. Thanks
