markme avatar image
markme asked
Victron MPPT 75/15
I have a 24V (25.6V) 100A LiFePO4 battery and an EcoFlow PowerStream, and I want to charge it with two solar panels, using a Victron MPPT 75/15 in between.
The specifications of the solar panels are:
• 425 Watts
• 132 Cells per panel (6×22)
• 1722 x 1134 x 30mm (LxWxH)• Module efficiency: 20.53%
• Open-circuit Voltage: 45.2V
• Max Power Voltage: 37.6V
Do you think this setup is safe and workable?
MPPT Controllerssafety
Alexandra avatar image
Alexandra answered ·
@Markme
Largely it will depend on for you are series or parallel connecting the panels to the charge controller.
How are you connecting the mppt to the ecoflow?
MPPT Product Page
MPPT Error codes
