sean avatar image
sean asked
MPPT 250/100 zero output.
I have a 250/100 with circa 1250 kWh on the clock that appears to have died in service.
Fw is current, voltage as expected on all terminals, just no production. Attached to a large Li bank/ESS/external BMS/parallel MPII/Fronius/PV Thor etc - the grid went down briefly yesterday, which isnt uncommon but everything usually restarts correctly with no intervention - oddly, when the grid was restored a brief "inverter overload" notification appeared, no apparent ill affects - perhaps the apparent MPPT failure isnt related.
Is there anyone @victron that might view its VRM in case I've missed something obvious please ?
It's likely still under warrenty.
MPPT Controllers
Jan Zmrhala avatar image Jan Zmrhala commented ·
Hi, did you check the settings of MPPT via Bluetooth and the APP? There could be wrong value in the battery tap - the voltage level can be wrong after such event.
Hi @Sean, what's the VRM id?
