reginald-potts avatar image
reginald-potts asked
vrm not showing controller state in both gx devices
I have two separate systems both with a gx device. The venus is connected to a single mppt controller via ve direct cable and when viewed in vrm clearly shows state of controller - bulk, absorp or float.
On the other hand the cerbo is connected to 3 mppt controllers via ve can and they all sync nicely together but unfortunately when viewed in vrm does not show state of the controllers.
Is this normal behaviour when using multiple controllers linked together or is there a setting I need to change to get the charging mode to show up in vrm?
TIA
MPPT Controllers
abuhanzala avatar image
abuhanzala answered ·
It’s common for the VRM not to show the controller state when multiple MPPT controllers are connected via VE.Can. It might be a limitation of the current setup. You could check the GX settings or firmware updates to see if there’s a fix, but this behavior is generally expected.
nickdb avatar image
nickdb answered ·
