For many years I have been a very happy owner of 2 Skylla-TG 24V chargers, 1 30A and 1 100A, installed in 2016 by the wonderful Frédéric of Tilikum in Le Marin, Martinique. The chargers have been giving me great service until suddenly this year the 30A charger started acting up. If it hasn’t been used for a few days, it stops charging after a maximum of 30 minutes. If I then reset it again, it stops right away. The weird thing is that his only happens when on shore power here in France, not when I run the generator while anchored.
The blink code I get when the charger stops is 4 red output voltage LEDs (26V), zero output current LEDs, the green On LED flashing on and off every second, yellow Boost LED on permanently, no Equalize and Float LEDs, and the Failure LED on permanently.
The 100A charger is working fine.
Does anyone have any helpful suggestions? Many thanks in advance.
Fair winds,
Roger
