In a setup with Multiplus II 48V 5KVA + MPPT + LFP battery 10KWh 200A (not victron, BMS included in the battery), we typically need a bus bar between those components as well as fuses and switches/breaker.
I'd like all bus bars, the DIN rail switches/breakers, the fuses to be inside a distribution panel for a clean setup. Can anyone recommend how to do or share examples.
Ideally, I'd like the panel to have remote monitoring features like the lynx distributor+smart BMS.
