Hi. I'm new to solar and bought components over the last two years, due to health issues I've only now been able to put a basic system into operation. I have a larger system going up next year and have controllers for both projects. Today I have a question about the smaller system. Both controllers are Victron MPPT: 150/35, the other 250/100. The panels are Sunpower 110W giving 18V in direct sun. Battery is 12V LIFEPO4 100AH
With one panel I get the expected readings in the Bluetooth app. When I put two panels in series I get double the voltage at the panels. When I attach the cables to the controller the voltage shows double that of a single panel, as I expected, but within moments it drops to the same voltage as one panel and I see no improvement in charging. It remains around 18V on the app and I thought equipment failure. However, I connected the 250/100 and the exact same thing happened. Removing the wires from the PV and measuring the bare wires with a voltmeter I get around 40V.
I expected around twice the charging capability with two panels in the same light but this is not the case. If anyone can suggest why my readings are as they are I will be most grateful.
