I have two Skylla-IP44 modules. Both used to work fine but I was only using them with the generator. Recently I started using them with shore power. One is working fine, the other is reported (on my CCGX) as OFF or Not Connected. Using the display on the device and going into Setup, I have the unit set to ON in the first screen in Setup. I have set to OFF and then back to ON numerous times but the CCGX always says it is OFF (if I was pushing buttons on the display recently) or Not Connected.
Any help would be appreciated.
