I have a Multiplus II GX 48/5000 with a BMV 700 battery monitor.
Every day the minimum SOC that the system will use keeps rising by ~2%
Can't embed photos to this post for some reason so here is a link:
https://photos.app.goo.gl/RaFXqRnVAgivykPD7
So a 3 days ago it would not discharge below 65%
2 days ago it would not discharge below 68%
1 day ago it would not discharge below 70%
ESS Optimise with battery life is on but the Active SOC Limit: is 20%.
Dynamic ESS is off.
Where should I start to troubleshoot the problem? Is there any other information that you guys need that would help?
Some maybe relevant information:
There was an issue just before with the battery % reading differently between the the BMV and Multiplus. That was rectified because the battery capacity was set to different values in BMV and Multiplus.
I keep getting
VE.Bus System [275] Low battery: Alarms throughout the evenings and mornings
