I'm trying to put together a system using Victron Smart 12/330 batteries. I plan to use a Smart Protect 220A for load disconnect via the VE Bus BMS V2. I would like to charge batteries with a Multiplus 12/ 3000 and an Orion XS 12/50A DC to DC charger. Do i need a charge disconnect between the Orion XS and the VE Bus BMS B2? Would a Smart Protect or Cyrix LI CT be appropriate? or is it necessary at all since the engine ignition would be shutting off charge? Thank you!
