stegzzz avatar image
stegzzz asked
Battery cell voltages
I have 2x Pylontech 5000 batteries and multiplus/victron mppt and whenever batteries approach full charge some cells are showing a higher voltage than others (up to 150mv difference). I was running max charge voltage of 52.4 as suggested by victron but this was triggering high voltage alarms so I usually have max charge voltage set at 51.8 to avoid these. I've tried running higher (up to 53.2v which is apparently what the pylontechs can take) to get batteries right up to 100% to try to balance them but of course this triggers alarms. Any advice on this? Carry on with the 51.8v and live with the imbalance?
battery chargingPylontech
daza avatar image
daza answered ·
