solhobby avatar image
solhobby asked
Bluetooth Communication between MPPT 100/50 and EPS32 board
With the smartsolar charge controller MPPT100/50 I want to retrieve data like state , current , battery voltage by means of bluetooth and store the data in a EPS32 board (Wemos D1 R32 )
Does anyone has experience in writing a sketches or any example sketches available for the EPS32 board.
Thanks in advance
Bluetooth
chrigu avatar image
chrigu answered ·
For bluetooth theres for example
https://github.com/Fabian-Schmidt/esphome-victron_ble
Im using this to read out a 100/20 over its VE.Direct port
https://github.com/KinDR007/VictronMPPT-ESPHOME
But keep in mind that the VE.Direct port is not able to supply enough power in order to run an ESP8266/32 off it. Ive used a Traco TMDC 06-4811 48V-to-5V converter
