I keep on having issues that any amount for "Grid to Battery" also is counted as "Grid to Consumption" in the DESS energy graph. As such, the consumption is always way too high if the battery is charging (it even affects the predictions). If I look at the console or VRM dashboard all live (Watt) readings are perfectly fine (AC loads are shown separately). Also in the advanced graphs, the currents and powers are fine, it's just the energy for AC loads that are somehow "peaking" when the battery is charging. In the hours that the battery is discharging it also seems that the loads are missing and there is barely any "Battery to Loads" visible. Example graph (image) at https://rmco.nl/cloud/index.php/s/BVlhlC9re6R8dmU because inserting the image still fails.
Is this a bug?
