I note that the 0V connections of both VE CAN and VE Direct are directly connected to the battery negative terminal on an MPPT. Does this not cause problems when there is voltage drop in the power cables? e.g the voltage difference between two MPPT negatives is directly connected across the 0V connections in the CAN and VE Direct cables.
Does it not create a hazard if a Battery negative connection were lost from an MPPT in that the entire MPPT current would go down the RJ45 cable?
