I have a small installation for an internet connection for a client, the consumption is direct current.
System composed of:
- Cerbo-S GX
- BlueSolar Charger MPPT 150/35
- 48/24V 10A converter
- smartshunt
- 4 gel batteries 150Ah 12V
The smartshunt had a temperature sensor connected but after a few months we removed it because it started to report very high temperature values (50 degrees) which does not correspond to reality. After removing the sensor, the charge controller continues to report error #1. I have already activated and deactivated the DVCC and nothing changed. It seems that it is stuck in the error. Can someone help me?
