Hi, I have 3x MPII 5000 in three phase configuration and everything seems to be working fine except the input current limit. I used VEconfig to set the input current limit to 23A on each inverter and disabled overruled by remote. But when I check the console on the cerbo and open the multiplus it says 6A. This morning I saw that grid meter was showing 1.8kW of usage due to washingmachine so I check why the ESS was not supplying more power to compensate this. Then saw the 6A current limit, so I downloaded the configuration files from the mutltis and all 3 showed 23A limit.
I'm on firmware version 551, anyone and idea what is happing ?
