James Stranger avatar image
James Stranger asked
No SOC on Cerbo GX
Hi everyone,
I just purchased a sailing boat fitted with amazing Victron gear (see below for details of products).
I updated the firmware as it hadn’t been done by the previous owner in a few years and now facing a non-critical issue of no SOC shown on the touch panel, but is shown on Smart Shunt interface in the app.
Things I’ve tried:
  1. Charge batteries through a full charge cycle (bulk, absorption, and float) with float being over 3 hours using the generator
  2. After float charging for 3 hours, manually set SOC to 100%
  3. Restart the system 100 times (cause that normally fixes everything haha)
  4. Recheck for more firmware updates.
The manual said that the SOC should be restored “auto-magically” once the system determines it’s reached 100% charge.
Additional helpful information:
  1. Batteries state they are “balanced”.
  2. “Has DC system” is disabled. Should I enable it?
  3. DVCC is disabled, Should I enable it?
  4. Service report https://1drv.ms/u/s!At-a4CooRT6qmMtQW6GSmzRndiD79w?e=EMOvJ1
  5. Smart Shunt settings: https://1drv.ms/u/s!At-a4CooRT6qmMtPO8vsxqirpoKfyw?e=26aZaJ
  6. Many screenshots of various settings shown for quicker reference (if helpful). I tried to keep them in order to make it easy to understand. https://photos.app.goo.gl/zWH9pjEWn8zTc4yx8
The system appears to be functioning correctly, just not displaying the right information on the panel. Also, a new blank rectangle has appeared after the update (in the lower right corner), not sure why or what it’s meant to do.
List of equipment
1 x Cerbo GX
3 x 12V/330Ah Lithium batteries
2 x MultiPlus Compact 12/2000/80-30
1 x Smart Shunt 500A/50mV
1 x MPPT 100/50
1 x MPPT 150/70
5 x 350 W solar panels
Multiplus-IIcerbo gxSOC
nickdb avatar image
nickdb answered ·
Double check the shunt is set as the battery monitor in gx settings, system setup
James Stranger answered ·
Yes, the Smart Shunt's "Monitor Mode" is set to "Battery Monitor"
No, that is something else.
On the GX console, settings, system setup -> you have to select the smart shunt in the "battery monitor" section.
