Today I installed a new system and added it to VRM with no problems. The Dashboard is working OK. I have 2 problems, If I select Venus Large in VRM I see Node Red and Dashboard. If I select Node red I get an application error notice. If I turn on HTTPS I get "
Tunnel to remote device was terminated or couldn't start.
The other problem is when I select remote console form the VRM menu I get this error
Failed to set up a connection to the GX device. Check your connection and try again.
If you whitelisted outgoing IPs or want to check the networking details.
On my local LAN the console and Node Red are working normally.
I checked all Cerbo VENUS settings on both installations and there are no differences.
Both are connected to the same local lan and both have a static IP
The 'OLD' installation everything is working perfectly
Every info is welcome
