I am looking to buy the IP22 30 amp 3 output ac charger to add to my boat. I already have the SmartSolar MPPT 50//100 and would like to achieve synchronised charging over the ve.smart bluetooth network feature. Is this possible with this combo? If so, given the IP22 charger has 3 outputs, are you given the opportunity in setup to select which of the 3 outputs (battery banks) you are synching other devices in the ve.smart network with?
Just for ref: I checked the ve.smart manual and it reports that the IP22 charger does support synchronised charging but goes into no detail as to what devices it supports this feature with.
Thanks, Paul
