I have a Victron 230V / 3600W isolation transformer connected to a Quattro on my boat.
The isolation transformer regularly delivers 250V - 259V AC due to the 1:1.05 winding ratio.
To protect the AC devices on the boat, the Quattro is configured to disconnect from the grid above 254V and reconnect again when the grid voltage dropped to 250V.
This happens multiple times per day and the Quattro can be disconnected for hours.
I understand the reason for the 1:1.05 voltage boost, but in my home marina (the Netherlands), the voltage supply is very good and does not need the voltage boost.
From the documentation, there does not seem to be extra taps on the transformer to bypass the voltage boost.
Any ideas on how to fix or mitigate this problem?
