herbinz avatar image
herbinz asked
Checking compatibility before I buy
I just want to check compatibility before I buy.
LifePo4 array. 8 X 3.6 volt = 28.8 volt.
Want to use:
Victron Energy Blue Smart IP22 Charger 24/16
Victron Orion-Tr Isolated 24/24-17A
Are these compatible?
Thanks and regards
Herman
victron products
jetlag avatar image
jetlag answered ·
The system voltage of the mentioned components is 24V. Although the voltages in reality are higher or lower in some situations, the naming is 24V.
So yes, both victron components you want to use are fine. You can alos check the datatsheets and you will find, that the real voltages of these two components are are within a range that fits to you battery and system voltage.
