dlclark avatar image
dlclark asked
Orion DC-DC Converter 30 AMP
Using an Orion DC-DC converter to charge Lithium battery bank. Input power from 12v AGM starting battery and either ALTERNATOR or SHORE POWER charger.
This was working and I would see about 25 amps charging the 12V 200 AMP Lithium house bank.
The batteries were discharged to about 45% and I noticed that with the ALTERNATOR running I was only seeing about 8 AMP of charge.
Back at the marina, the shore power charger is rated at 25AMPS and ORION DC-DC converter is only puting out about 10 AMPS - but would only do this after disabling the engine parameters.
Do I have a defective ORION DC-DC converter?
orion-tr smart
Justin Cook avatar image
Justin Cook answered ·
Please clarify the product you're using? The Orion-Tr (non-smart) DC-DC Converter is not a charger, and should not be used as such, but your product tag lists the Orion-Tr Smart DC-DC Charger, which is a different product and functions differently.
