ET340 measures three phase grid input to control single phase ESS (on phase 1).
The voltage reading are strange and consequently the power input/export seem off
for example on phase 1 voltage is 217.9V; on phase 2 voltage is 230.5 V and phase 3 voltage is 259.7 V.
PV production is measured with a CT attached to Multiplus II on phase 1 and reports at the same time a voltage of 236V (ET340: 217.9)
recently my connection to the grid was renewed. Also the Multiplus was reconnected and changed from phase 2 to phase 1 (as it should be). Can someone guide me what steps to take to determine what is wrong with the ET340? Thanks in advance.
ps I tried to insert a jpg to illustrate the issue but I get the "Parsing response failed" message ...
