mediaone avatar image
mediaone asked
Multiplus II Compact - Battery Charging Issues
My Multiplus battery charger is only supplying between 0 and approx 4 amps, despite it being in bulk charge mode with ample room in the batteries to accept a charge (12.3 sys voltage). I do have a 10 amp shore limit set, but I’m not using any of that budget on the AC side of my boat. Thoughts?
I’ve power cycled the unit, checked all programming, I don’t get what the issue is.
Side note: I’m measuring 109V on the AC leads to the unit, but it reports 97V.
Multiplus-IIcharger
nickdb avatar image
nickdb answered ·
