tjscott avatar image
tjscott asked
3 Phase Inverters for 127/220V, 50HZ Grid ?
I am building a fairly Property on the Island of Curacao. The Electricity Grid here is unusual 127/220V, 50HZ. From my research I should be using a 3 Phase inverter. When I researched the Certifications required for Curcao, they are also unusual. I am on the finance side of building not tech, so I am wondering if you have a 3phase system that has these certifications? And if not - does any company carry these, that could hybrid with your line of products? Thank You.
CE Certification
Safety: EN-50178 of IEC623109
Harmonischen: IEC 6100-3
EMC: IEC 6100-6
Netbewaking
VDE AR-N 4105 of VDE0126-1-1
3 phase
pj2sg avatar image
pj2sg answered ·
Hi there,
With victron equipment you can build a 3 phase setup using either their multiplus or quattro inverter options. It can be configured for 127 / 220 50Hz.
I am also on curacao and have a couple of systems running. If you need more info on your install feel free to ask away.
