Hi VIctron Forum
Just a question about this inverters AC inlet RCBO size and the 70A charger in the compact.
My shore power inlet is rated to 15A and Victron recommend a 16A RCD/MCB or RCBO between the inlet and the inverter so when I see the compacts charger can put out 70A I'm wondering how it doesn't trip everything downstream?...Is this because the charger is putting out DC?...and if so can I use 70A to charge batteries without tripping a 16A breaker?
Any insight here would be very much appreciated...TY in advance!
