Hello, i have a strange problem, my setup:
1 Fronius symo 12kW
3 Multi Rs Solar 2 tracker in three phase system
3 multiplus2 5000VA in also thre phase system
The system working for following:
Fronius connected to the MP output, ESS setup is complet, and its working fine. The RS system also connected to the MP output and generating power for whole house, its also fine working.
I have 38kWp solar panel, and 120kWh Lifepo4 , this system is connected to the grid throught multipluss, the exceed energy feeded back to the grid. The feeded back energy measuring is quite correct, but I dont see the AC load in the vrm app. I have an energy meter directly connect to the main connection, its measurinf and reporting to the vrm. Its ok, i have a second energy meter which is measuring the AC load its working fine but i dont see in vrm.
First energy meter role 3phase and grid meter
Second one is AC load an also 3 phase.
The phase L1 L2 L3 is corretly setup
How can i eliminate this problem?
