Have a 250 w portable solar panel that I want to connect to a 100amp life po4 lithium battery. Will the victron mppt 75 l 15 be suitable?
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
Assuming you are using it at 12v...
Watts is volts x amps.
250w on a 12v battery is 20 Amps. (250w÷12v=20a)
So more ideal is a xxx.20 mppt. Unless you don't mind clipping the power a bit. Or you know your irradiance and panels temps will mean you never see full power.
107 People are following this question.
