Reading VE.Direct Protocol BlueSolar and Smart Solar MPPT chargers manual, I found at page 9 this text:
"Battery Settings Registers
WARNING: stored in non-volatile memory. Continuous writing, for example from a control loop, will lead to early failure"
Does it mean that only battery settings registers are stored in non-volatile memory? To be clear: Does constant writes to other registers, different to battery settings registers, like 0xEDAB, lead to early failure? Are these other registers stored in a memory that is not the non-volatile?
