For our 20KwH 48v Battery bank, can we simultaneously use the Multiplus 11 charging at max 3500w and add another high output charger such as the 48v Chargeverter max 5000w? Total maximum charging would be 8500 watts. BMS for each battery is 250 amps.
The Chargeverter would be set with higher cut in and a lower cut out voltages than the Multiplus 11.
