wiringocd avatar image
wiringocd asked
2 Quattro setup 50 amp RV. L2 no power
So i have a 50 amp RV with a 2 Quattro setup Configured as a L1 and L2. Up until 3 days ago into my trip everything worked as it should. But now that i have reached Alaska and all of a sudden my L2 is no longer accepting power in. This has happened at 3 different Parks. Every park i have measured the pole with a DMM and have 220 at the pole, 120 on each leg. Tested with my surge protector and no open grounds or neutrals. Removed the cover off the Inverters and checked all wiring connections everything is good and tight. What would cause L2 to just stop accepting power?
