jandrovich avatar image
jandrovich asked
MPPT 75/15 load output works in strange ways
The MPPT is connected to my 400W 45 volt solar array. I want to power a 12V pump from the load side terminals. A 12V battery is connected to the BATT terminals The load output won't work regardless of settings on the app unless I also connect the 12V pump directly to the battery. This is inconvenient since I don't want the pump running constantly. Any advice will be appriieciated1
MPPT Controllers
The inrush current of the pump might be to high and is detected as a short circuit.
What power does the pump have?
jandrovich avatar image jandrovich commented ·
Thanks for your reply. The pump specs shows it draws 180 watts and about 12-13 Volts DC when connected directly to the 12V battery. I will check amperage and let you know that reading later today.
Alexandra avatar image Alexandra ♦ jandrovich commented ·
@jandrovich
No need - 180w ÷ 12v is 15A
The inrush to start then would be higher and so above the mppt load port capability.
Maybe use the load port to signal a relay (that connects the fridge to the battery terminals) to disconnect load.
jetlag avatar image
jetlag answered ·
By the way, the solar array is also way to big for this MPPT. You have almost double as much connected then recommended...
