offgridpower avatar image
offgridpower asked
ET112 energy metre not visible in Cerbo GX using Zigbee
Hi folks
Having some trouble getting an ET112 energy meter working with Zigbees. The ET112 is installed in the consumer unit after the master switch, before the loads. The Zigbee to RS485 has a fast flashing RX/TX light and a fast flashing Active light. the Zigbee to USB (Cerbo side) has a flashing RX/TX light and constant Active light.
The green “Power On” light on the ET112 is on but no other lights and it’s not visible on the Cerbo.
Any ideas on what the issue might be or any advice?
Thanks,
Nigel
Multiplus-IIESSEnergy Meter
