greg-johnson avatar image
greg-johnson asked
Cerbo (ekranos) - connect via BT to Smart Shunt?
My smartshunt works fine using the VictronConnect app, but I cannot see to connect it via bluetooth to my new Ekrano GX (Cerbo GX). Is it possible or do I have to run physical VE.direct cables?
It would be a great shame if the BT connectivity was not available between Victron devices!
Thank you,
greg
cerbo gxVenus OSekrano gx
nickdb avatar image
nickdb answered ·
Bluetooth is not for connecting devices to a GX. This is documented. The GX is about wired connections as BT is not reliable for larger system use.
greg-johnson answered ·
I tried to find some documentation, but failed. My Ruuvi's are connected to the Cerbo via BLE, and I'm quite happy with that. Perhaps it could be considered for read-only, non-safety critical applications where the wiring is a real PITA (especially as VE-direct uses a connector that was designed for internal PCBA harnesses, not as an external customer-facing connector)?
I since saw the announcement that @mvader (Victron Energy) made in 2021 ( https://community.victronenergy.com/questions/93919/victron-bluetooth-ble-protocol-publication.html ) and then followed up in 2023 ( https://community.victronenergy.com/questions/187303/victron-bluetooth-advertising-protocol.html ) so I will continue in that thread as it seems like development efforts are ongoing to make this possible, even if not quite yet.
nickdb avatar image
nickdb answered ·
There are no plans to support bluetooth as a means of a GX coordinating its devices. BT is for small systems and vesmart networking, which should not be mixed with wired, as it can cause conflicts.
Ruuvis and Mopeka are supported as sensors, but on most GX's, requires a dongle.
The rest of the integration is for local connectivity to VictronConnect for management of supported smart devices.
Justin Cook avatar image
Justin Cook answered ·
In some cases the marketing team has gotten ahead of the technical team in some of the documentation... it is documented that the Cerbo/Ekrano BT is not for connection to Victron Smart devices, but unfortunately it's buried in footnote 4 of the tech data at the end of the manual rather than being a big note right at the top - people have been understandably confused by that limitation since pretty much day 1 of the Cerbo release.
https://www.victronenergy.com/media/pg/Cerbo_GX/en/technical-specifications.html#UUID-e926e227-6ab9-2110-20b0-d75733f3cbad
